查看: 14912|回復: 0
Subaru Boxer Engine 水平對臥引擎簡介
發表於 2012-4-20 17:32 | 顯示全部樓層 |閱讀模式
不論是86還是BRZ
都採用鼎鼎大名的SUBARU水平對臥引擎(Boxer Engine)
這邊有稍微介紹一下水平對臥引擎的優勢
http://www.subaruofkeene.com/subaru-boxer-engine.htm
SUBARU BOXER ENGINE
WHY A NEW OR USED SUBARU IS THE RIGHT CHOICE FOR YOU AND YOUR FAMILY
The Subaru Boxer engine sits at the heart of every Subaru vehicle. The intelligent engineering behind the Boxer engine provides the get-up and go you expect from a Subaru, and provides plenty of power for Subaru's symmetrical AWD system. The flat laying engine design provides the perfect combination of balance, power and efficiency. The Subaru Boxer engine is what makes a Subaru a Subaru.
水平對臥引擎超棒
Subaru Boxer Engine Design
How the Boxer Engine Works
The horizontally opposed Subaru Boxer engine gets its name from the way that the pistons move. The pistons move horizontally, in a side-to-side manner like two boxers punching. This unique design to Subaru and certain Porsche models creates a lower center of gravity, perfect symmetrical balance, better handling and a more efficient AWD system . The pistons in typical V-shaped engines move vertically in a "V" shape, or up and down at a slant. This creates wear and tear, reduces fuel efficiency on AWD vehicles and requires more parts for an AWD system.
顧名思義水平對臥引擎就是水平而且對臥
活塞式水平運動的就像拳擊手在出拳一般
(英文的BOXER就是拳擊手所以BOXER ENGINE就是拳擊手引擎)
SUBARU跟部分的PORCHE採用這種形式的引擎來得到更低的重心、更優的平衡、更棒的操控還有更有效率的AWD
(可惜到目前為止86跟BRZ都沒有AWD四驅車型的計畫)
其他像是V型(V6、V8)或直式(直4、直6)的垂直活塞運動方式會造成磨損而且降低燃油效率
AWD系統也需要更多的零件
Why the Subaru Boxer Engine is Efficient
Notice the graphic on the left; did you see punch-counterpunch movements of the Boxer engines pistons? The opposing pistons cancel out each other's movement, with creates a smoother running engine without the need for additional hardware that most V-shaped engines require.
水平對臥引擎的活塞震動會互相抵銷所以運作平順
不像V型引擎需要額外硬體來解決
What Engine Types Does Subaru Offer?
When asked about engine type, most people are familiar with the term V-6 or 4-cylinder, or perhaps V-8. The "V" stands for the style of the engine, while the number after stands for the number of cylinders. On traditional engine designs, typically the more cylinders mean more power, but also less fuel economy. However, Subaru's Boxer engine uses advanced engineering to get the most power and fuel economy out of smaller engine designs.
Subaru carries the flat-4 or flat-6, which refers to the engine design and number of cylinders. Subaru's efficient engine design is best highlighted by the Subaru WRX STI , which carries a turbocharged flat-4 engine that cranks out 305HP and goes 0 to 60 in 4.7 seconds. Because the Boxer engine has a low center of gravity, the engine does not weigh the car down and utilizes power efficiently. The STI reaches high-performance car speeds with a fraction of the engine size. Come check out our Boxer engine, standard in all Subaru vehicles, at Subaru of Keene .
水平對臥引擎比起直式跟V型引擎的重心更低更穩定
The Performance Advantages of the Subaru Boxer Engine
Lower Center of Gravity
The horizontal design of the Subaru Boxer engine is more than just good looks under the hood. The nearly perfectly symmetrical engine sits flat and low to the ground. This creates superb handling around tight corners, better balance and makes for a safer vehicle. Typical V-shaped engines don't have a perfectly balanced design, which reduces efficiency and safety. Check out our Subaru Safety Center to learn why Subaru is one of the safest vehicle manufacturers.
更低重心
Fuel Economy
The efficient design of Subaru's Boxer engine and meticulously crafted symmetrical AWD system provides our Subaru vehicles with excellent fuel economy. In fact, Subaru carries the most fuel-efficient all-wheel drive vehicle lineup in America.
Power
更低油耗
The Subaru Boxer engine cranks out 170HP on the nimble Impreza base, and goes up to 305HP on the Impreza WRX STI. All Subaru vehicles come with plenty of horsepower and torque for the get-up and go that driving enthusiast's value. The efficient and powerful Boxer engine will never make you feel underpowered in your Subaru. Come down to Subaru of Keene to try our powerful engines for yourself.
更大馬力
Subaru Boxer Engine Safety Advantages
Subaru Engine Accident Dismount
No one expect an accident to occur, but if it does let Subaru protect you and your family. In the event of an accident, the Subaru Boxer engine disconnects and slides underneath the vehicle, away from the driver and passengers. A safety concern of typical V-shaped engines is engine penetration inside the vehicle, which can cause injury and death. The safe engine design is what makes a Subaru a Subaru.
發生意外時
水平對臥引擎不會往駕駛艙擠壓
Handling and Balance
Preventing an accident is part of Subaru's commitment to our numerous active safety features. The flat and balanced engine design along with the standard AWD system helps keep the vehicle on the road, regardless of conditions. A balanced engine is a safer engine because it allows for easier avoidance of road obstacles and handling, without the engine weighing one side of the vehicle down.
防止意外發生正是SUBARU著名的的主動安全
水平對臥引擎造就更好的操控、更優的平衡也更能避免意外的發生
GMT+8, 2025-11-25 23:07 , Processed in 0.052015 second(s), 9 queries , File On.
