查看: 17463|回復: 28
大家來分享機油的實用吧~
發表於 2013-12-3 13:07 | 顯示全部樓層 |閱讀模式
小妹我車換過2次日本線Motul 0W-20機油,除了車輛平安,有些耗油外,沒有特別其他感覺
目前心儀想要買的 法國產 Motul 300V 好像買不太到
時光匆匆,86上市已經過了一年有餘,站上也有很多大大有推荐過機油,
請問有大大可以分享已經使用過的機油,那些比較有心得的嗎?
發表於 2013-12-3 14:30 | 顯示全部樓層
http://cy-motul.com.tw/front/bin/ptlist.phtml?Category=110890
Made in France
看來不錯,參考看看
發表於 2013-12-3 14:41 | 顯示全部樓層
網站裡面寫建議三千公里更換
發表於 2013-12-3 15:28 | 顯示全部樓層
可以團購1箱,真的很划算耶
發表於 2013-12-3 15:47 | 顯示全部樓層
有住北部的要一起團購嗎???
發表於 2013-12-3 16:00 | 顯示全部樓層
一個舊的連結, 機油參數, 更新至2011年..
http://g9677606.blogspot.tw/2011/04/40100hthstbn2552011113.html
一個使用過機油檢驗報告, 可以參考測試項目
http://www.bobistheoilguy.com/fo ... &Number=2309011
以下為三個油商的建議哩程
Mobil 1
Manufacturer Recommendations
Exxon Mobil, the manufacturer of Mobil 1 synthetic motor oil, recommends that users change the synthetic oil every 15,000 miles. For those who drive less than 15,000 miles in a year, the company recommends an oil change at least once a year to prevent the breakdown of oil viscosity. The company also points out that this interval will suffice even for those who frequently drive in heavy traffic.
Red Line
Q: How often should I change my Red Line oil?
It depends on how you drive. If you do a lot of city driving or low speed/low frequency driving, we recommend oil changes at 7500 miles. Vehicles that see more highway driving can go a maximum of 15,000 to 18,000 miles with an oil filter change in between. Modern filter technology and the latest, clean-burning fuels have reduced the solids that contaminate oil, so frequent filter changes aren't usually necessary.
Motul
300V is not designed for extended oil change intervals, therefore it should be changed after track/race events, at 3000 miles on ultra high performance street vehicles or at 5000 miles on lower performance engines. APR Recommends 300V Power 5w40 for most high performance racing applications and 300V Le Mans 20w60 for 24 hour endurance racing with Audi R8 V10's. APR does not recommend use of low viscosity 300V oils for extended periods of time as the lower viscosity oils were not intended for street or long track use. For help choosing the correct 300V oil, please contact APR.
發表於 2013-12-3 16:31 | 顯示全部樓層
最好3000換 尤其少開的
常開高速的  可以拖到4000-5000吧
我目前是300V 0W20的愛用者
 樓主| 發表於 2013-12-3 17:05 | 顯示全部樓層
pagani 發表於 2013-12-3 16:31
最好3000換 尤其少開的
我目前是300V 0W20的愛用者
大大都去哪買 300V 0W20
發表於 2013-12-3 18:03 | 顯示全部樓層
我之前是用300V 0W20,上週保養時改用300V 5W40
聽很多前輩或過水平對臥引擎的車主都說,想要引擎用久一點的機油要用系數高一點的
5W40或5W50最好,但缺點會比較不省油(耗油),很多說法,所以我選擇用黏一點的機油來保護引擎
發表於 2013-12-3 18:36 | 顯示全部樓層
常換就好。
GMT+8, 2025-12-31 18:52 , Processed in 0.055221 second(s), 9 queries , File On.
